I can not use Hook with Zotero
Hi, I am Tsutomu from Japan.
I read Using Hookmark with Zotero Using Hookmark with Zotero – Hookmark
I set it up.
But I can not use Hook with Zotero.
Hook shows: No linkable item in Zotero.
What do I do?
Please let me know.
Hook: Version 6.5 (6117; Integration v. 345)
Zotero: 7.0.7
Welcome to Hookmark forum, @Tsutomu .
If you selected a record, press shift+commad+c, what do you get?
Does your Settings->Export looks like below:
Thank you for response.
Yes, I set it up.
Settings->Export
item format: Markdonw item URI
But Hook cannot get Markdonw item URI from Zotero.
Just want to make sure, can you use the shortcut to get the markdown URI?
Yes, my Zotero gets a Markdown item URI when I press shift+xommond+C.
My Zotero also shows Copy as Markdown item URI in Menu item.
Screenshot 2024-11-25 at 17.55.29
Thank you for the info, @Tsutomu .
Could you please
(1) Select a record in Zotero
(2) Run the following script in Script Editor and see if it return a markdown link?
Summary
tell application id "org.zotero.zotero"
	activate
set the clipboard to ""
delay 0.1
tell application "System Events" to tell process id "org.zotero.zotero"
	keystroke "c" using {shift down, command down}
	delay 0.1
	repeat 20 times -- poll clipboard for ~2.5 seconds. Sometimes set x to the clipboard throws exception
			set markdownLink to the clipboard
			if markdownLink is not equal to "" then
		delay 0.1
return markdownLink
Thank you for your response.
I run the script.
Script seems not to return a markdown link.
Could you please run the following script in Script Editor and see if it throws any error message?
Script
	activate
delay 0.1
	delay 0.1
		on error errStr number errorNumber
			display dialog errStr
		delay 0.1
return markdownLink
I run the script.
Script Editor seems to throw no error message.
Nothing happens.
log
tell application "Zotero"
	activate
tell application "Script Editor"
	the clipboard
	the clipboard
	the clipboard
	the clipboard
	the clipboard
	the clipboard
	the clipboard
	the clipboard
	the clipboard
	the clipboard
	the clipboard
	the clipboard
	the clipboard
	the clipboard
	the clipboard
	the clipboard
	the clipboard
	the clipboard
	the clipboard
	the clipboard
Result:
Replies
	activate
	the clipboard
	the clipboard
	the clipboard
	the clipboard
	the clipboard
	the clipboard
	the clipboard
	the clipboard
	the clipboard
	the clipboard
	the clipboard
	the clipboard
	the clipboard
	the clipboard
	the clipboard
	the clipboard
	the clipboard
	the clipboard
	the clipboard
	the clipboard
Result:
Hi, what version of macOS are you running? It seems to me the plugin is not working on your system for some reason.
Hi,
My Mac is macOS Sequoia 15.11.
I made a clean install of MacOS 15.1.1
Hookmark can get Zotero link.
Thank you for your support.
