How to verify my Pro license is working
I’m very new to Hookmark. I bought the Pro license several months ago, and now after a lot of my own delay and then license confusion, I’m suppose to have Hookmark Pro. But I’m not so sure that that’s what I ended up with. My big question: How can I verify that I’ve got Hookmark Pro and not Basic?
If you go into the hookmark settings and go to the update tab, you should be able to see what version of hookmark you are running. Mine shows Hookmark Pro version 6.3, I would assume it would show something else if you are not running the pro version.
Done! Thanks very much, @tylermcrae7
