I have some broken links in Hook, which I can see them in search results, but I wasn’t able to find a way to delete them.
Is there any way to do so?
Is this related to the problem noted in the OP?
thanks for letting us know. Exporting and importing link data would fix this issue. General Preferences Tab – Hook. There are tips on using the export there such as ensuring that removable media (volumes, mount points, disk images, network drives, USB, shares), to which you have bookmarks are mounted.
Thank you for your answer.
I exported link data, and it is almost unreadable.
Do you have any plan in the roadmap of adding a feature of visualizing and managing Hook links? That would be nice.
Yes, we have a couple of additional additional graphical user interfaces in development.
Good to hear that. I’m looking forward to it.
