The fact that the Hook URLs are persistent is a huge advantage and I can finally “manage” my files using links without worrying that they will break. My second brain or personal encyclopedia is a local MediaWiki installation but sometimes I need these links to be in another format. As a result I wrote an AppleScript in order to easily get links in various formats.
The files in Finder need to be selected from top to bottom (with no gaps) otherwise the script does not work properly. While the script is running Finder should always be in the foreground and no user interaction should happen. The links are sent to the clipboard at the end of the script.
The script is the following:
tell application "Finder"
	activate
	set the clipboard to ""
	set theLinks to ""
	set selectedItems to the selection
	if selectedItems is {} then error "Please select at least one file."
	set numberOfItems to count of selectedItems
		repeat (numberOfItems - 1) times
			key code 126 -- up arrow
			delay 0.5
	set theType to chooseRefType({"Markdown", "MediaWiki", "RTF", "HTML", "LaTeX", "Mathematica"}) of me
	activate
	set indexItem to 1
	repeat numberOfItems times
		activate
		set itemName to name of item indexItem of the selectedItems
		delay 1
		--get the Hook URL
			--activate Hook
			keystroke space using {command down, shift down}
			delay 1
			--Copy Link
			delay 1
			set HookURL to do shell script "pbpaste"
		if theType is "RTF" then
			set the theLink to createLink(itemName, HookURL, "HTML") of me
			set theLinks to theLinks & theLink & "<br />"
			set the theLink to createLink(itemName, HookURL, theType) of me
			set theLinks to theLinks & theLink & return
			key code 125 --down arrow
		set indexItem to indexItem + 1
		key code 126 --up arrow
	if theType is "RTF" then set the theLinks to createLink(itemName, theLinks, "RTF") of me
	set the clipboard to theLinks
on chooseRefType(linkType)
	set linkType to item 1 of (choose from list linkType with prompt "Choose the type of link:" default items {"Markdown"})
	return linkType
end chooseRefType
on createLink(linkText, linkURL, linkType)
	if linkType is "RTF" then
		set linkHTML to "<html>" & linkURL & "</html>"
		set the clipboard to linkHTML
		set theLink to do shell script "pbpaste | textutil -stdin -format html -convert rtf -stdout" as «class RTF »
	else if linkType is "Markdown" then
		set theLink to "[" & linkText & "](" & linkURL & ")"
	else if linkType is "MediaWiki" then
		set theLink to "[" & linkURL & " " & linkText & "]"
	else if linkType is "LaTeX" then
		set theLink to "\\href{" & linkURL & "}{" & linkText & "}"
	else if linkType is "HTML" then
		set theLink to "<a href=\"" & linkURL & "\">" & linkText & "</a>"
	else if linkType is "Mathematica" then
		set theLink to "Hyperlink[\"" & linkText & "\",\"" & linkURL & "\"]"
	return theLink
end createLink
