Hello,
TLDR: My question is if there is a small group of items hooked to one primary item, is there a quick way to hook each item to each other
I’ve had hook for a while and just started playing with it again. I am wondering if there is a way to simply consolodate hooks between a group of hooked items. For example, I am a litigator, and I have the following workflow for creating to case files
(1) Obsidian for Notes (title = Case Name)
(2) Omnifocus for Todos (project = Case Name)
(3) OneDrive folder in Finder for Draft documents (folderName = Case Name)
(4) New Devonthink Database (database = Case Name)
I usually create the file in Obsidian, and hook to the other three. Now, is there shortcut to make it so that if I bring up items hooked to number (1), that they will all hook to each other? (i.e. (2) hooked to (1), (3), (4); 3 hooked to (1), (2), (4); and (4) hooked to (1), (2), (3).
Sorry if I’m missing something. The only way I see to do this is to rehook from each item.
Thanks!
