I have been trying to find out when my current license (not sure it is pro or essential) and when it would expire. How do I do it
You can find that info in Hook about window.
1.Open Hook window
2. Click on Gear button
3. Click on About Hook menu item
Or you can use short command+’
ah, you are right. It is the fine print that I did not read thoroughly. May be I should suggest the font to be more ‘senior’ friendly
