Because we are publishing many very useful automation Shortcuts for Hookmark that enable you to copy links and hook stuff together, it is helpful for you to know how to assign keyboard shortcuts to macOS Shortcuts automation.
Very easy to do from Shortcuts app.
quoting from Run a shortcut while working on your Mac - Apple Support (CA):
Trigger a macOS automation shortcut with a keyboard shortcut
- Setup: In the Shortcuts app
on your Mac, double-click a shortcut, click
, click Add Keyboard Shortcut, then press a key combination.To remove the keyboard shortcut you added, click the âRun withâ field, then press Delete.
- Run the shortcut: In any app in macOS, press the key combination.
Note: Some keyboard shortcuts are reserved for system use and cannot be overridden.
Example: Finder Mesh linking (âHook Selected Files Togetherâ)
Hereâs how to assign a keyboard shortcut to our âmesh linkingâ shortcut
see also
Rant about Appleâs choice of names for âShortcutsâ (âNotesâ, âMessagesâ) etc.
Apple made a silly, self-defeating apparently arrogant, mistake when it called its ânewâ automation tool âShortcuts appâ. This is utterly confusing for users of all levels of expertise in programming and in English, because âkeyboard shortcutsâ long predates Appleâs terminology.Apple itself has âkeyboard shortcutsâ! Apple got away with the âiPadâ brand name (as I predicted on the date of its announcement); but it will not get away with its poor choice of words here. Even experts find it very hard to google its automation shortcuts. Itâs 2021-11 and Google hasnât learned intent, nor will it. Not Googleâs fault.
In addition to making it difficult to specify web searches, Appleâs terminology makes it difficult to refer to shortcuts in documentation.
How to get out of its bind? Apple could preserve âShortcutsâ and add a prefix, like Automation Shortcuts. If it retires its workflows app, it could call them âWorkflow Shortcutâ. After all, itâs Shortcuts tech is a repackaging of the Workflows app it bought. But I will leave it to Apple to think of something better.
While weâre at it, Apple calling Notes âNotesâ, and âMailâ mail is also arrogant and problematic. There are many note taking apps. Usurping the term âNotesâ made it very awkward to refer to multiple types of notes in one document. To be clear we need to say âAn Apple Notes noteâ.
I prefer the ways of âiMessagesâ, etc. etc. Iâd prefer iNotes, and iShortcut. Think Iâm nuts? well, Apple does not call its phone the âPhoneâ. Nor the iPad the âPadâ.
