How Do You Use Hook to Stay Focused During Research?
Hello everyone,
I’m relatively new to the use of Hook and have been playing around with it while working on research-intensive tasks. I find that I lose articles, notes, and sources as I switch between apps and websites. Hook has already assisted me in linking a couple of PDFs to Obsidian notes, but I just feel like I’m scratching the surface.
I was wondering: how do you utilize Hook to maintain concentration and organization while heavy research or writing sessions are in progress? Do you primarily employ it with certain apps such as DEVONthink or Obsidian, or is there a more general workflow that keeps distractions at bay while your mind remains fixed on the task at hand?
Also, any tips on setting up a structure or “flow” with Hook that works well for long-term projects or writing would be awesome. I’m trying to develop a routine of gen ai Online Course that helps me reduce mental clutter and keep everything connected without having to search manually every time.
Looking forward to hearing how others are making the most of Hook in their daily productivity and knowledge workflows!
Thanks in advance!
The Hookmark App Videos are a good place to start. They illustrate using Hookmark with various apps. There are also Showcases – Hookmark.
It’s also a good idea to explore the Action ☰ button menu and the gear button to discover useful commands. One of my favorites is Reveal File in Finder that you can call in link-friendly file based apps like TextEdit and BBEdit.
Hookmark also has a Bookmarks window.. After you’ve pinned a bookmark it appears in the pinned section. That’s a good placeholder for entry points to your projects. You can also simply search in the Bookmarks window to find what you’re looking for.
