Hookmark Settings dialog disappears
Steps to reproduce (please use the exact order):
  • Select Hookmark → Settings
  • Click on “Update” tab
  • Click on “Sync” tab
  • Click on “Advanced” tab
  • Click on “Services” tab
Result: Settings dialog is minimized to lower left corner of screen and disappears. To make it visible again, I have to quit Hookmark and restart it.
MacOS Tahoe 26.3
Hookmark 7.0
Thank you for reporting this issue, @rainerc . Truly appreciate it.
We will fix it.
Hookmark 7.0.1 is available. Could you please update your Hookmark and see if it fixes the problem?
Bug is fixed with 7.0.1. Thank you so much!
