I’ve been trying to create links in Notion to link to OmniFocus Perspectives. I found out Notion doesn’t support custom protocols like omnifocus:/// but I heard about Hookmark’s universal link feature which seemed like it would do the trick.
Now I’m looking everywhere for Copy Universal Link, but it is no where to be found.
I’m so confused. Where did it go?
Don’t know if this has anything to do with it, but I switched to the Setapp version of Hookmark a few months back — is that the problem? There doesn’t appear to be any documentation of differences between the versions.
Hi, I’ve been trying to do the same, unfortunately, when I open a perspective in Omnifocus with nothing selected, hookmark returns a “No hookable items” error.
Can I ask how you’ve managed to make it work?
Thanks!
Hmm, I beg to differ:
if you right click on a perspective in the perspective side bar, you get the option to copy link. Pasting it in a text editor you get something of the form omnifocus:///perspective/tags
and putting this in safari will open the Tags perspective in safari.
That said, I agree that you can’t get it from the main menu because you can’t really “select” a perspective, so in that sense, i could see why making hookmarks work might be difficult.
edit; you can “select” a perspective from the Perspective list, but again, you can only “Copy as link” from the contextual menu, not the main menu, so I’d imagine the problem remains the same.
I’m assuming when using a universal link and it is clicked then a user connects to Hookmark’s servers to retrieve the translated link? These URL’s unfurl when pasted into an application (email for example) with subject, email address, etc. What if we can’t reach Hookmark’s server? And what information is Hookmark storing with Universal Links (if any)?
This follows the universal links pattern proposed by Apple which many other apps use.
no information about the link is stored on the server.
the first time you click on a https://hookmark.net universal link an association between that domain and Hookmark will be stored on your Mac. That does require an Internet connection and access to this server. Thereafter you don’t need an Internet connection, the association is resolved locally.
