Hookmark isn't working with Capacities
I cannot activate the Hookmark window in the Capacities Mac app. When I use Ctrl + H to trigger Hookmark in Capacities, the Hookmark window keeps flashing and does not load.
I reported the issue to Capacities. They reviewed it, found no problems on their end, and advised me to seek support from Hookmark.
I am attaching a screen recording demonstrating the issue (link shared)
https://share.cleanshot.com/vX4NhWgF
I use Capacities Version 1.43.47 (1.43.47) & Hookmark Version 6.6 (6136; Integration v. 348)
Please explain how to proceed.
Thank you for reporting this issue, @sudeepshroff .
Hi
Could you please share when it is likely to be resolved? or any workaround it?
My workflow is dependent on Hookmark’s integration with Capacities.
Thanks.
Regards,
Dr. Sudeep
Sorry about this, @sudeepshroff .
We are working on it. We will let you know as soon as possible.
Any news in regard to this topic?
I encountered the same issue, I also frequently use the Capacities linking feature, hope it can be resolved soon
