Hookmark integration v. 277 is now available with improved deep linking for OmniOutliner. Now when you click on a deep OmniOutliner link, Hookmark will cause OmniOutliner to scroll to the row referenced by the deep ink (previously the row was just selected).
Recent updates
c. 2023-05-10, we released version 276 with these improvements.
- Fixed a deep linking issue that caused repeated opening of an OmniOutliner
- Improved deep linking support for Bike (introduced in version )
- Fixed an issue for Users of Ulysses on Setapp.
Software update
The latest updates were released via Hookmark’s software integration service. Simply use the Check for App Updates and Update Scripts... to get the latest, without needing to relaunch Hookmark. Or enable automatic software updates in Hookmark.
Hookmark’s automatic software update (if enabled) automatically updates Hookmark’s integration scripts without you needing to relaunch Hookmark. Using Hookmark’s Check for App Updates and Update Scripts command also updates the scripts, without you needing to relaunch Hookmark.
This requires a valid Updates license.
