Hookmark integration v. 244 is now available.
Copy Link and Copy Markdown Link in Slack Mac app now return links whose names are of the following form:
<Slack> - <Workspace> - <Date>
that will make it easier for you to make sense of these links, whether you paste them in Hookmark (as “hooks”) or somewhere else.
Earlier, in version 243, we added Craft’s Hook to New integration to Craft for Setapp, placing it on a par with the standalone version of Craft.
How to get the updated integration
Hookmark’s automatic software update (if enabled) automatically updates Hookmark’s integration scripts without you needing to relaunch Hookmark. Using Hookmark’s Check for App Updates and Update Scripts command also updates the scripts, without you needing to relaunch Hookmark.
This requires a valid Updates license. Or Pro users can add the updated integration themselves.
