bchend
2
Sorry about this issue. Could you please take a process sample of Hookmark when it hangs? Here is how:
bshi
3
If you have external disks, mounted DMG files or network files, could you please disconnect/dismount them and try again?
Thanks for the quick response.
I no longer have a reproducible failing test case :-(.
After posting my discourse bug-fix;
- I tried to reduce the number of links.
- by tediously searching and deleting ~/.Trash/… links ( over 6,000 of them!) using the Show Bookmarks window.
- I then tried the export on the remaining 2,847 links and (after 26 minutes) it successfully completed the export (29.2 mb)!
I’m unsure as whether no longer having any ~/.Trash… links or the reduction of 26,000 too 20,847 links contributed to the success.
One thing I did notice was:
- After doing the recommended shutdown/restart of Hook before export, Hook used 45.9 mb.
- Hook’s memory utilization peaked at over 500 mb during the export and returned to 78 mb at completion.
Could the original problem be related to garbage collection thrashing with large hook.sqlite database (100 mb)?
FYI: I noticed after removing the ~/.Trash/… links the size of hook.sqlite didn’t get smaller… even after a Hook restart.
Is there some option to reclaim the deleted space (more for performance than disk footprint consideration)?
