I am on MacOS11.4 and using current version of the hook app.
When I click the menubar icon, the hook window does not open, and I get this error. Can you help troubleshoot?
could you please try in context of different apps. It may be that the app you’re trying to use Hook with is slow to respond.
Normally, if you do “continue” the request should complete. If it does not, it suggests the app itself has an issue.
A debugging approach is to paste Hook’ script for the app in Apple’s Script Editor app, and hitting the run button.
