Currently, there is no way to Hook to individual references in Endnote. Anyone know a way that this could be done?
Thanks!
Thanks!
last time we checked Endnote lacked automation.
If Endnote has comments fields, you could paste Hook-garnered links in them.
I implemented this on endnote 20: GitHub - aitsc/endnote-hook
Thank you for implementing this!
We will integrate it into Hook.
Welcome to the Hook Productivity Forum , @tsc. Thanks for sharing!
We’ll need to replace the python3 call with some ObjectiveC since Apple unfortunately removed python.
We’ve modified the New Item script because macOS does not have Python anymore
could EndNote users please let us know if the following works for them?
# given hook://endnote/?dn=1-1954,1-2093&l=SCI|Area 3&or=false
# Where dn represents the number of the database opened (starting from 1) - the number of the paper #, ..
# l represents the label to be retrieved, different words are separated by vertical bars |, or if true, it means that the relationship between different words is or for retrieval, the default is false and the relationship
# will not encode the url itself, if dn has a value, the l parameter will be ignored
on path2url(thepath)
tell current application's NSString to set urlString to stringWithString_(thepath)
set theDecodedURL to urlString's stringByRemovingPercentEncoding -- 4 is NSUTF8StringEncoding
return theDecodedURL as Unicode text
end path2url
set fullURL to path2url("$0")
on theSplit(theString, theDelimiter)
set oldDelimiters to AppleScript's text item delimiters
set AppleScript's text item delimiters to theDelimiter
set theArray to every text item of theString
set AppleScript's text item delimiters to oldDelimiters
return theArray
end theSplit
on intersection(list_list) # 多个list求交集
local newList, listB, a
set newList to item 1 of list_list
repeat with listA in list_list
set listB to {}
repeat with a in listA
set a to contents of a -- dereference implicit loop reference
if {a} is in newList then set end of listB to a
set newList to listB
return newList
end intersection
on union(list_list) # 多个list求并集, 一个list内部重复的元素会去除
local listA, listB
set listA to {}
repeat with listB in list_list
set listA to listA & listB
set listB to {}
if {a} is not in listB then set end of listB to a
return listB
end union
set l_or to "false"
if (count of text items of fullURL) is greater than 1 then
set fragment to item 2 of theSplit(fullURL, "?")
set AppleScript's text item delimiters to "&"
set kvs to text items of fragment
repeat with kv in kvs
set AppleScript's text item delimiters to "="
set k to text item 1 of kv
set v to text item 2 of kv
if k = "dn" then
set database_recNum to v
if k = "l" then
set Label to theSplit(v, "|")
if k = "or" then
set l_or to v
if database_recNum ≠ "" then
set myResults to {}
repeat with dr in theSplit(database_recNum, ",")
set database to item 1 of theSplit(dr, "-")
set recNum to item 2 of theSplit(dr, "-")
set end of myResults to "<RecordID database=\"" & database & "\" recNum=\"" & recNum & "\" />"
tell application "EndNote 20"
set myResults to {}
repeat with l in Label
set end of myResults to find l in field "Label"
if l_or = "true" then
set myResults to union(myResults)
set myResults to intersection(myResults)
activate
show records in myResults in first window
Sorry. Here is the modified Open item script:
use framework "Foundation"
# 链接例子为 hook://endnote/?dn=1-1954,1-2093&l=SCI|3区&or=false
# 其中dn表示 打开的数据库编号(从1开始)-论文的编号#,..
# l表示检索的Label, 不同词使用竖线|分割, or如果是true则表示不同词是或的关系进行检索, 默认为false是且的关系
# url不要自己encode编码, dn如果有值则会忽略l参数
end path2url
return theArray
end theSplit
set listB to {}
return newList
end intersection
local listA, listB
set listA to {}
set listB to {}
return listB
end union
set l_or to "false"
if k = "dn" then
if k = "l" then
if k = "or" then
set l_or to v
set myResults to {}
set myResults to {}
activate
Thanks again, @tsc.
@tsc and/or other Endnote users: Does the modified version work for you?
I just started getting interested in possibilities with Hookmark and gave this a try. It is some time later since these posts were first made, so I’m using Endnote 21—I didn’t remember to update the version number in the script but there was a mac prompt that asked me where the app was and so I just pointed to the correct place and it worked (I updated it later in the scripts too).
It seems like the hook works as expected - you can select a single reference or multiple references, and when you open the link it will return exactly what was selected before. One thing that might be interesting to update in the script is the link title so it doesn’t just say “en”. There seem to be ways to extract reference fields (i.e., author) using AppleScipt, but this would break the use case of hooking multiple references at the same time.
Also, based on the way Endnote libraries are compiled, this likely won’t work on different computers or if you update your library (the reference numbers in Endnote aren’t persistent in that way).
Welcome to Hookmark forum, @andrew_m_j .
I am not familiar with EndNote. How can I update library so the reference numbers will change?
I change the script so the url is not depending on the order of how the libraries are opened. The url will include the file path to the library. So the drawback of it is you can’t rename or move the library file.
Normally, how many libraries a user have? If most users will have 1 library, then better use the script in previous post.
on urlDecode(input)
tell current application's NSString to set urlString to stringWithString_(input)
end urlDecode
set fullURL to "$0"
set AppleScript's text item delimiters to "?"
set urlPath to text item 1 of fullURL
set fragment to text item 2 of fullURL
if k = "rn" then
set rn to v
if k = "fp" then
set fp to v
set fpath to urlDecode(fp)
set text item delimiters to "/"
set fn to text item -1 of fpath
set len to length of fpath
set fpath to text 8 through len of fpath
set targetWindow to missing value
tell application id "com.ThomsonResearchSoft.EndNote"
activate
repeat with i from (count of windows) to 1 by -1
set thisWindow to window i
set thisDoc to file of document of thisWindow
set thisDoc to POSIX path of thisDoc
if thisDoc is not missing value and thisDoc is equal to fpath then
set targetWindow to thisWindow
if index of targetWindow is not 1 then
set index of targetWindow to 1
if targetWindow is missing value then
open fpath
set targetWindow to first window
set re to item 1 of (retrieve "all" records in first document)
set xmlDoc to make new XML data with properties {text:re}
set dn to value of XML attribute "database" of XML element "RecordID" of xmlDoc
show records in {"<RecordID database=\"" & dn & "\" recNum=\"" & rn & "\" />"} in first window
set f to file of first document
set myPath to POSIX path of f
set rawURL to NSURL's fileURLWithPath:myPath
set f to rawURL's absoluteString
set myResults to retrieve of "selected" records in first document
set r to item 1 of myResults
set en to field "Title" of record r
set xmlDoc to make new XML data with properties {text:r}
set rn to value of XML attribute "recNum" of XML element "RecordID" of xmlDoc
return "[" & en & "](endnote://?rn=" & rn & "&fp=" & f & ")"
Set scheme name:
