One thing that I would love to be able to do, is to Hook to a heading or block ref in a specific note, and not just the whole note. I am not too savvy to figure out all the nuances or blockers for this implementation. I know the Advanced Obsidian URI has the capability of generating a URI to open a note at the block or heading level. Just can’t quite figure out a work around with Hook. If anyone has a way, advice, or knowledge if this is even feasible that would be appreciated.
The current version of this Obsidian plugin is able to conveniently copy block links from within Obsidian. If block/header links can be copied in the format of Obsidian URL, then they can used to hook to any items by using Hook.
I can right click to copy block link and Hook it to new file using Hook to copied link. However, when I invoke the copied link it just open the file and doesn’t navigate to block.
Here is the link to the Advanced URI plug-in.
Here are two examples from the GitHub.
Open heading “Goal” in “my-file.md” (Important: Without syntax, only Goal): obsidian://advanced-uri?vault=&filepath=my-file&heading=Goal
Open block-id “12345” in “my-file.md” (Important: Without syntax, only 12345): obsidian://advanced-uri?vault=&filepath=my-file&block=12345
Hook a desired file to the copied URI to the block
@LucB It would be great if the copied link can be somewhat improved by Hook, though. Specifically, if the file link is copied by using Hook in the format of the official Obsidian URI, a Markdown link would be generated. Therefore, it would great if the copied Block Link in the format of the Advanced URI plugin can be converted by Hook into something like [File#^blockid](obsidian://advanced-uri?vault=xx&filepath=yy.md&block=blockid), to reflect both the file name and Block ID.
