When a group (folder) is selected in DEVONthink’s sidebar, Hook say’s “no linkable item”. All documents and groups (including tags) in DEVONthink have an “Item Link” that is discoverable via OSA script. So, Hook should be configurable to find the URL of a group.
Sample, which works when the item selected is a group in the sidebar.
tell application id "DNtp"
set theSelection to the current group
set theURL to the reference URL of theSelection
set the clipboard to theURL
No changes over here. It still looks to me that the DEVONthink 3 Hook scripts for Get Name and Get Address should work for group selections but are not working. Hooking to groups is a good use case – it is too bad it is not supported for whatever reason. Maybe CogSci and DEVONtech could do a bit of collaboration to help us users?
In the meantime, a workaround is to create any type of document you wish and use it as an “anchor document” hooking multiple items to it as you would if you could hook to a Group.
So if you wanted to have a Devonthink Group called “Interesting notes” you can create that group now and then inside that group create Markdown file called “Notes Anchor” and then hook all of your desired notes to that anchor file.
Sorry this fell through the cracks. @grahamb’s in Jan 2020 updated our internal issue database about this, but I forgot to update the issue’s milestone and communicate:
Works on groups. If a group is selected in the sidebar, and no items within are selected, Hook links to the group.
Also other such categories (tags, rules, inboxes, etc).
Does not work on global smart groups or global smart rules. Seems like a bug, because it works with other globals (tags, inboxes) and works with smart groups and rules which are within databases. I’ll send a message to devs, but it’s a very minor issue.
I would see nothing wrong with Hook linking to DEVONthink SmartGroups, etc. – but would prefer that the linking to ordinary groups work before anything else is explored, please.
I’ll need your help to debug this because I can’t seem to reproduce the issue with my current arrangement of settings and databases in DEVONthink.
Fortunately, I do think I have a fix, I’ll just need you to test it for me. Do you have any experience with editing Hook scripts? If you open Preferences>Scripts and then scroll down the list to select “DEVONthink 3” you can edit the integration scripts Hook uses to get the name and address of records in DEVONthink.
Copy and paste to replace the Get Name and Get Address scripts in the preferences window with the following, and make sure you click Save when you’re done:
Get Name:
if exists (content record of current tab of window 1) then
-- current open item
return name of (content record of current tab of window 1)
if class of window 1 is in {viewer window, search window} then
set selected_items to selection of window 1
if (count of selected_items) = 1 then
-- current selected item
return name of item 1 in selected_items
-- selected group
return name of theSelection
Get Address:
return reference URL of (content record of current tab of window 1)
return reference URL of item 1 in selected_items
-- selected group
return the reference URL of theSelection
These new scripts are almost the same as the old, but I’ve replaced the section which is supposed to get the selected group (the lines at the very bottom) with some code based on the snippet that @katie_v included in the original post.
Sorry @grahamb, the revised scripts result in the same “No linkable item found…” message. I’ve tried this in all the possible configurations of panels and windows in DEVONthink.
If I run the Get Name script in Script Debugger, with a group selected, the following error occurs:
I do not get the error when a document is selected in DEVONthink 3, nor when I run the Get Address script in Script Debugger.
Thanks for your patience, I’ll definitely reach out to Criss if this doesn’t work, but based on your Script Debugger error, I think I might have figured out where the issue was. Do me a favour and try these scripts:
Get Name
tell application id "DNtp" -- "DEVONthink 3"
if class of window 1 is equal to viewer window then
-- selected group
Get Address
-- selected group
I had to quit and restart Hook for them to work for me. I don’t know why. But if you can release them in the next Hook scripts update, please, we would be done with this issue I think.
