I just contacted with Apple Support to solve the issue that when I open a popup window from System Settings, the alert sound keeps playing in regular intervals. After multiple troubleshooting attempts (restart, safe mode, reinstall MacOS), I came to test each app and realize Hook was the cause.
When I quit Hook, the popup window stays opened without the alert sound beeping.
Yes, it does make a difference. When I turn off Show current item’s number of hooks in menu bar icon, it stops beeping alert sound in System Setting popup window.
Hope it is fixed.
Thank you for pointing that out.
we have updated the script server with the fix for the macOS Ventura Settings. So users may re-enable the badge in menu bar icon when they’ve received the fix (no restart of Hookmark required .)
