Hook integration v. 220 is now available.
This improves integration with
- the classic edition of Evernote,
- the Agenda Momenta Date-focused note taking app by Momenta B.V., supporting multi-language integration. This requires Hook 3.6 or newer. If you’ve already installed Hook 3.6, the Agenda support is the same. And
- Reminders app.
How to get the updated integration
Hook’s automatic software update (if enabled) automatically updates Hook’s integration scripts without you needing to relaunch Hook. Using Hook’s Check for App Updates and Update Scripts command also updates the scripts, without you needing to relaunch Hook.
This requires a valid Updates license.
Topic updated 2022-06-09 4:12 PM PDT.
