Hook integration v. 215 is now available. It supports deep PDF links, to specific locations in PDFs, to Nitro PDF Pen Pro.
background
Nitro acquired PDFPen and PDFpenPro last year. Nitro PDF Pro is the rebranding of Smile Software’s PDFpenPro app. Nitro PDF Pen and Nitro PDF Pen Pro are both available on SetApp, Mac App Store and as direct downloads.
Hook’s basic linking already worked “out of the box” with both Nitro PDF Pen and Nitro PDF Pen Pro.
New
This new integration (v. 215) brings deep linking with Hook productivity to Nitro PDF Pen Pro.
Manifesto for Ubiquitous Linking
Angel Vu of Nitro is an originator of the Manifesto for Ubiquitous Linking . You can sign it too!
How to get the updated integration
Hook’s automatic software update (if enabled) automatically updates Hook’s integration scripts without you needing to relaunch Hook. Using Hook’s Check for App Updates and Update Scripts command also updates the scripts, without you needing to relaunch Hook.
This requires a valid Updates license.
