praj
1
Hi Team,
Hope you are doing well!
Could you please consider creating a hook script for this app named FirstSeed Tasks.
For those interested, It is probably the best Kanban app on the macOS, and although the premium is expensive, the free version has a ton of features.
It’s got a “Copy Link” option on right clicking a task, so I was wondering if that helps.
Thanks in advance!
Happy hooking!
Thank you for requesting this feature, @praj .
Do you know if there is a keyboard shortcut for “Copy Link”? Hookmark can’t access the menu item in the context menu.
praj
3
Hi,
Thank you for the question. I have asked the developer if he can implement a shortcut for this function, as it appears there isn’t one at the moment.
Will keep you posted on what happens.
Cheers!
