I have a pdf stored on pCloud. I created a hook link which works fine from the computer the link was generated. It does not work on a different machine that has the same iCloud and Hook app installed with iCloud sync enabled.
Thank you for that. Could you please use Copy Markdown Link instead of just Copy Link and then paste the result? That will allow us to see how the name lines up with the URL.
Also, just to be sure, please copy the name of each file directly from Finder. (in a way that we know what name goes which what Copy Markdown Link result.)
[Memo Change in Terms for Don (54027-002) Green Farmland Demo_complete.pdf] (hook://file/CyERpL1nZ?p=cENsb3VkIERyaXZlL015IEZpbGVz&n=Memo%20Change%20in%20Terms%20for%20Don%20%2854027%2D002%29%20Green%20Farmland%20Demo%5Fcomplete%2Epdf)
[Memo Change in Terms for Don (54027-002) Green Farmland Demo_complete.pdf] (hook://file/CtV5LPwiH?p=cENsb3VkIERyaXZlL015IEZpbGVz&n=Memo%20Change%20in%20Terms%20for%20Don%20%2854027%2D002%29%20Green%20Farmland%20Demo%5Fcomplete%2Epdf)
Thank you for the links! I tested pcloud on my machines and the links seem to be working fine.
May I ask is your pcloud drive on network drive? If yes, could you please
(1)quit Hook,
(2)Run the following command on Terminal
defaults write com.cogsciapps.hook hfile.url.search.scope network
(3)Start Hook
And see if it make any differences. It might take a bit longer to open the file.
