I have been using Hook for 10 months and it’s great.
While using the browsers (Firefox, Chrome, Safari), I have been able to invoke Hook and it can recognize the URL automatically and be ready for me to copy the link as markdown formatted link.
However, a few days ago, it is not working with Firefox (v 104.0.2). It said “No linkable item found found in Firefox”. It still works with Chrome (latest version) and Safari (latest version).
My Hook is using script version 230.
I tried to reboot and update Firefox, but didn’t help.
I am not able to reproduce the problem. What’s your macOS version?
Could you please copy the following script to Script Editor, run it in Script Editor and post the output here?
Summary
use framework "AppKit"
-- classes, constants, and enums used
property NSShiftKeyMask : a reference to 131072
property NSAlternateKeyMask : a reference to 524288
property NSControlKeyMask : a reference to 262144
property NSEvent : a reference to current application's NSEvent
set modifier_down to true
repeat while modifier_down
set modifier_flags to NSEvent's modifierFlags()
set option_down to ((modifier_flags div (get NSAlternateKeyMask)) mod 2) = 1
set shift_down to ((modifier_flags div (get NSShiftKeyMask)) mod 2) = 1
set control_down to ((modifier_flags div (get NSControlKeyMask)) mod 2) = 1
set modifier_down to option_down or shift_down or control_down
tell application "Firefox"
activate
delay 0.05
set myName to get name of front window
set firefoxVer to version
considering numeric strings
set is87 to firefoxVer ≥ "87"
set is72 to firefoxVer ≥ "72"
end considering
if is72 and myName ends with " - Mozilla Firefox" then
if length of myName > 18 then
set myName to text 1 through -19 of myName
set myName to ""
if is87 then
set theUrl to ""
if toolbar "Navigation" of first group of front window of application process "Firefox" exists then
set theUrl to get value of UI element 1 of combo box 1 of toolbar "Navigation" of first group of front window of application process "Firefox"
else if toolbar "导航" of first group of front window of application process "Firefox" exists then
set theUrl to get value of UI element 1 of combo box 1 of toolbar "导航" of first group of front window of application process "Firefox"
else if toolbar "Área de navegación" of first group of front window of application process "Firefox" exists then
set theUrl to get value of UI element 1 of combo box 1 of toolbar "Área de navegación" of first group of front window of application process "Firefox"
else if toolbar "Navigazione" of first group of front window of application process "Firefox" exists then
set theUrl to get value of UI element 1 of combo box 1 of toolbar "Navigazione" of first group of front window of application process "Firefox"
else if toolbar "ナビゲーション" of first group of front window of application process "Firefox" exists then
set theUrl to get value of UI element 1 of combo box 1 of toolbar "ナビゲーション" of first group of front window of application process "Firefox"
else if toolbar "導覽" of first group of front window of application process "Firefox" exists then
set theUrl to get value of UI element 1 of combo box 1 of toolbar "導覽" of first group of front window of application process "Firefox"
else if toolbar "Navegação" of first group of front window of application process "Firefox" exists then
set theUrl to get value of UI element 1 of combo box 1 of toolbar "Navegação" of first group of front window of application process "Firefox"
return ("[" & myName & "](" & theUrl) & ")"
keystroke "l" using {command down}
keystroke (key code 53)
--keystroke "c" using {command down}
tell process "Firefox"
repeat 50 times -- poll clipboard for 5 seconds
set myText to (the clipboard)
if myText is not equal to "" then
delay 0.1
set theClipboard to current application's NSPasteboard's generalPasteboard's stringForType:(current application's NSPasteboardTypeString)
return ("[" & myName & "](" & the theClipboard as string) & ")"
Have you switched Firefox to a new language or changed the keyboard shortcuts associated with Firefox? Firefox lacks URL-automation; so Hook relies on UI scripting to control it.
Meanwhile, you can copy the link from the Firefox address bar, and use Hook’s Focus on Link in Clipboard to access Hook on any given web page.
Thanks for the extra info, @jakekei . In my tests, Hook still works well with Firefox. The following suggestions will hopefully do the trick: No Linkable Item in … – Hook.
I have the same issue as Jake, above. Hook on Mac stopped working with Firefox around a week ago, with ‘No linkable item’. Other browsers still work (I do understand that the mechanism for Firefox differs from other browsers).
Firefox 105.0, Hook 3.8 4940 v 231, MacOS 12.6, Macbook Pro 2021 M1.
Thank you for Hook, which I love, I’ve been looking forever for an app that does what Hook does!
I have the same problem with Firefox 105.0.1. A new installation of Hook (as a new user) and it does not function automatically with Firefox. Manually copying the link and ‘focus on clipboard’ and saving link… works but only gives the URL when searching it later in Hook. Tried the tccutil reset AppleEvents, for the second time gave Firefox permission, and that had no effect on fixing this fault. Safari and other apps of mine work fine. It’s just Firefox (which is my default browser).
Tried this, but alas, still no joy.
Super-duper frustrating that this Firefox problem cropped up this morning… effectively DESTROYING my daily workflow.
So annoying that it does not work with Firefox latest version. I reset accessibility again and shutdown mac and then restarted to find the same problems exist.
If anyone with the issue would please try using the following Firefox “get address” integration script, please let us know the result. It would involve replacing Firefox “get address” integration script in Script Editor with the following. I.e., please
open Hook Preferences,
choose Script Editor tab,
scroll to Firefox,
click on the Get Address tab, and
copy paste the following into the tab, and
click save.
activate
delay 0.05
if version > 72 and myName ends with " - Mozilla Firefox" then
set myName to ""
end considering
set theUrl to ""
if is87 then
click menu item "Copy" of menu "Edit" of menu bar 1
delay 0.05
We expect to publish an auto-update integration script today (the auto-update takes effect if one does has not overridden the particular script.
The above fix will work for vast majority of users. It basically reverts to Hook 3.7.1
We have another fix coming (probably later today, Sunday) based on the 3.8 version.
Those who override the integration script in Hook’s Script Editor (by pasting a script in the ‘get address’ tab) will not get the automatic update to this script however. (Hook respects your overrides.)
background: Something seems to have changed in Firefox which interacts with Hook 3.8 but not the 3.7.1. It’s a change in a default Firefox setting value, so it does not affect all Firefox users. I.e., users who manipulated that firefox setting may or may not have encountered the problem. Our upcoming version of the script will handle these different cases. Our Firefox integration scripts are visible to Pro users in Script Editor, so those who understand AppleScript will be able to understand the full details of the changes.
Firefox is a UI-scripted app (as marked on apps page) so the integration is a bit circuitous, and we have enhanced the integration multiple times since we released the initial integration years ago.
We have released an update on the Hook integration server with which Hook connections when you Check for App Updates and Update Scripts... (Gear Menu > Advanced; or Preferences > Updates). If Hook is configured for automatic updates you will get this automatically. In either case, no rebooting of Hook is required for integration updates.
This addresses the issue.
For users who don’t want to see the flashes of copying a ULR from the address bar(which might break their automation workflow). Here is what to do:
Open Firefox
Enter about:config in address bar
Accept the risk (if you want to, see below) and continue
Search for accessibility.force_disabled
Set accessibility.force_disabled to -1
Either way, there’s a bit of a lag because Firefox lacks adequate automation (per below).
On one of our Macs, turning machineaccessibility.force_disabled machine on/off is set to -1/0. But in Firefox support page, it is 0/1.
cf:
Turning this on might have performance and security issues. Your choice.
If Firefox were a link-friendly app, i.e., conformant with the meager requirements of the Manifesto for Ubiquitous Linking, integration would be very simple. There are plenty of browsers that do conform. Firefox does not, so we marked it as on the linkable apps page. Having said that, I myself use Firefox for some of my browsing.
