Hi, I recently manage to jerry-rig an integration between Hook and Taskwarrior-tui which is a interactive terminal interface for Taskwarrior. I’m happy to provide more details if you’re interested, but in case nobody is I’ll keep my explanation brief.
I always run taskwarrior-tui in iTerm, so I have set up an integration script for iTerm in Hook.
The script runs a keyboard maestro script. (this is because I find shell scripting easier than applescripting. It’s possible that you could do this all in Applescript without needing KM.
The KM script opens iTerm and presses ‘1’. Taskwarrior-tui is configured to run a custom script when 1 is pressed. This script simple dumps the GUID of the currently selected task to a known file path.
The KM Script then reads the GUID from this file, and runs taskwarrior to get the description of the task.
KM returns the description of the task and the GUID back to Hook’s script for it to form the URL.
Another trick is that I have a separate script that runs regularly to tag any taskwarrior tasks that have something hooked to them. This just uses Brett Terpstra’s Hook CLI to get search the hook database for the GUIDs of active tasks and then add a tag. Then in the taskwarrior interface I can see which tasks have hooks attached.
FWIW here is a screenshot of what it looks like. 1) is the tag showing there is a hook on this task, and 2) is showing that the task is linked to a word document
The Hook script is a bit nasty because “Get address” calls the keyboard maestro script and “Get name” assumes that that has already been run. If Hook decided to run these functions in a different order, then it would stop working.
tell application "Keyboard Maestro Engine"
do script "tw_get_tui_url"
set taskID to getvariable "var_tw_task_id"
return "kmtrigger://macro=tw_open_task_by_uuid&value=" & taskID
do script "tw_get_tui_name"
set taskText to getvariable "var_tw_task_title"
return taskText
Finally the keyboard maestro macro that is called when Hook is run for my iTerm terminal is
