after the Tinderbox-Hook zoom meeting today I would like to share my script to create a new note in TBX with the “Hook to new…” command. Just copy this under “Preferences/Scripts/New Item”:
use framework "Foundation"
tell application id "Cere"
if (count of documents) is equal to 0 then
return "No document is available"
set openFile to file of front document
if openFile is missing value then
return "Hook can't link unsaved files"
set filePath to my encodedPath(POSIX path of (openFile as alias)) as string
tell front document
if not (exists note "Inbox") then make new note with properties {name:"Inbox"}
set theContainer to note "inbox"
set myNote to make new note with properties {name:"$title"} at theContainer
set tinderboxURL to value of attribute "NoteURL" of myNote
set tinderboxURL to (text (1 + (length of "tinderbox://")) thru -1 of tinderboxURL)
set tinderboxURL to "tbx://" & tinderboxURL
return tinderboxURL & "?filepath=" & filePath
-- encodedPath :: FilePath -> Percent Encoded String
on encodedPath(fp)
tell current application
(its ((NSString's stringWithString:fp)'s ¬
stringByAddingPercentEncodingWithAllowedCharacters:(its NSCharacterSet's ¬
URLPathAllowedCharacterSet))) as string
end encodedPath
is there a variable like $title (or any other option) to get the link of the copied target? I would like to add the link into an attribute in Tinderbox.
Welcome to the Hook Productivity Forum , @webline . And thanks for the above script. I tried quickly to make it work but had a glitch. Will revisit this on Monday.
I don’t want to seem pushy but will Hook give me access to a selection made by the user when Hook was opened (for example a text selected in Safari) too?
reason was that in my quick test I didn’t have a Tinderbox note open, which the script required.
Currently Hook only copies the selection in certain cases via a different command: Copy Selection and Link – Hook. That’s currently for PDF apps that support deep linking.
Thanks again, @webline ! We’ve adapted this with minor changes (dialog box) in Hook integration. This leads to 2 dialog boxes at the moment. CogSci Apps will need to change something under the hood to prevent that.
Normally our integration scripts select /open the newly created item. The current version of the integration does not select the newly created note. I suppose Tinderbox’s AppleScript has a way to do that which we can address.
I added one line of code to my version of the script:
set value of attribute "URL" of myNote to "$user_link"
I think this fits well to the way Tinderbox handles notes from external sources.
P.S.: if you like to show/open the new note in TBX a simple “activate” would do tell application id "Cere" to activate
And you could store the path to a default file in the script and then use
set theTBXFile to "/Users/myname/Documents/Tinderbox/sample.tbx"
set theDialogText to "Store to your default file or the frontmost file?"
display dialog theDialogText buttons {"Frontmost", "Default"} default button "Default" with icon caution giving up after 5
if the button returned of the result is "Frontmost" then
set theTarget to false
set theTarget to true
if theTarget then
open theTBXFile
