Announcing a new version of Hook beta:
2019-02-06 (Version 1.0-beta (1983) built 2019-02-05)
New
2932 InputW: Visually indicate (better) that “Link to Copied Address” is enabled
Fixed:
ID Comp Summary
2923 Menubar When “Link to Copied Address” is enabled, display a + icon to the left of “Link to Copied Address”
3079 Preferen AppleScript updating fails if DefaultAppAppleScript.plist absent (removed from) Hook’s Library folder
1427 Integrat Make Bookreader work from its Library window too
