Hello,
I’m running Hazel app from Noodlesoft so when a new folder is created somewhere, it automatically add a new task via an apple script. I’m trying to add one Hazel rule to run also a macOS shortcut which would create an apple note and my goal would be Hookmark all of these, link to finder folder, link to note, and link to Omnifocus project.
I almost succeed unfortunately I don’t understand why, the link to the finder goes to somewhere else => /Users/username/Library/Group Containers/group.is.workflow.shortcuts/Temporary/com.apple.shortcuts.Run-Workflow/4E10DA11-AD26-4470-9C4C-A164C0AC02A5/wahou
where “wahoo” is the name of the folder but it doesn’t link to the original one.
Here is my shortcut:
Maybe I should try with apple script? I thought it would be easier to create and find the apple note. I’m not really a programmer as you may have understood DIY kind of guy
Thanks for your help!
