Help with modified Evernote script
One problem with Hook generated Evernote links is that when they are pasted in a document, they look like any other link. It is not obvious that it’s an evernote link.
My idea was to change the Hook Evernote Get Name script so that the link starts with Evernote-
but it does not work. Would you have a suggestion ?
thank you
tell application “Evernote”
if (count of selection) is equal to 1 then
set originalTitle to title of item 1 of (selection as list)
set newTitle to “Evernote-” & originalTitle
set title of item 1 of (selection as list) to newTitle
Hi @ronny213,
This also addresses the more general request of how to customize the names of links generated by Hook.
Here’s one:
"Evernote: " & (get title of item 1 of (selection as list))
you can apply the same pattern to any script whose title you’d like to modify that way. This means one can customize the names of links generated by Hook for objects of particular apps.
See:
thank you Luc
The new Evernote script above does not work with Hook.
With your new script
evernote:///view/240968/s3/ad1bc334-f870-4ccb-8ac3-f199465c412b/ad1bc334-f870-4ccb-8ac3-f199465c412b/
Pasted link with the old script
Macro to switch toggle default browser between Safari, Chrome and Firefox - Questions & Suggestions - Keyboard Maestro Discourse
Error below when I run it in script debugger
I also don’t understand how to make changes for Scrivener (no get name script)
thank you Luc. Your help is greatly appreciated
Looks like I forgot to mark the text as preformatted, so the quotes around Evernote were pretty (not pretty as far as scripting goes). Try this:
tell application "Evernote"
		tell item 1 of (selection as list)
			note link
I think that you are overworked.
You pasted the script for Link, not get name.
Even then, I understood your point and ran the script taking out the quotes and it still does not work
Evernote: & (get title of item 1 of (selection as list))
Oh my universe, that’s fascinating from a cog psy perspective ! Very sorry about that. Here is the Get Name script!
works perfectly. Merci Luc !
Absent minded from time to time: it’s the cost of being a genius !
“being genius” : I wish!
But the company’s delighted to participate with the collective intelligence of this community to make it easier for people to access the information they need to do great work :slight_smile: .
Luc,
As far as adding prefixes are concerned,
  • you solved Evernote
  • I have the solution for the Scrivener
  • one last request of this type: how would I modify the Bear script to add Bear: prefix
I have no clue where and how I would modify the script, because the note ID is used in the callback
merci beaucoup Luc
Get name script
tell application "System Events" to tell process "Bear"
	click menu item "Copy Note's Identifier" of menu 1 of menu bar item "Note" of menu bar 1
	delay 0.05
		delay 0.05
open location "bear://x-callback-url/open-note?id=" & (the clipboard) & "&x-success=hook://title-callback/title///"
Get Address script
    	click menu item "Copy Link to Note" of menu 1 of menu bar item "Note" of menu bar 1
    	delay 0.05
    		delay 0.05
    get the clipboard
I am a newbie. Where do I put the EN script solved by Luc? Sounds like a stupid question, so just excuse that part!
Hello,
Certainly not a stupid question. It’s confusing.
Hook → Preferences → Scripts→ Evernote → Get Name
Gook luck !
Based on your name, are you japanese ? I studied japanese 11 years with a private tutor, many years ago.
Many thanks. That’s very helpful. I am an Indian and reside in India!
