Having Hookmark running creates bookmarks in Microsoft Word when copying and highlighting text
Hi!
I’ve had a really annoying bug in Microsoft Word recently (see image), and I think I finally figured out the problem.
Whenever I highlight or copy text in Word, it will randomly create bookmarks in my Word document. These are distracting while working, and I have to manually delete them all before I can collaborate on the document with others.
After systematically testing things based on a response in a Word forum, I’ve found that Hookmark is likely the source of this issue. When Hookmark is running, I have the problems in Word. If I quit Hookmark, the problems go away.
Is there anything I can do to be able to continue using both Hookmark and Word without this issue?
Thank you!!
MacOS 13.4.1, M1 Pro
Hookmark v5.1.3
thanks for reporting this. we have a fix for this in house. It might be available in Hookmark 6 beta.; I’ll have a look.
Thank you! I appreciate your quick response!
Sorry about this issue, @jtb .
If you install Hookmark 6 beta, Could you please also update the script to the latest one(version 287) ?
