I am using Hookmark 5.0.2 and when I hook a file in Forklift to something else - the hook works.
But when I request a Markdown link for a file in Forklift, I get back:
“hook://application/com.binarynights.ForkLift-3” which takes me TO Forklift but not to the specific file.
I had a quick try and Forklift still works. The code for hooking and copying links is the same, so it would be surprising for there to be a difference. Is it possible there was a slight difference in how you did the two?
