Hello all
I am regular user to Hookmark, whcih I have had on my computer for a year. I love it… Its great.
I do have one question if I may. Is it possible to have the bookmarks open up to the Bookmarks tab rather than Pinned?
Just asking…
Many thanks
Dj
Welcome to Hookmark forum, @deljones .
Yes, you can. Just run the following command in /Applications/Utilities/Terminal:
defaults write com.cogsciApps.hook bookmark-window.default-view all
Then restart Hookmark.
@bchend Fantastic.. Done..
Many thanks
Dj
@bnm3215 ,Are you suggesting we add another option like this?
defaults write com.cogsciApps.hook bookmark-window.default-view lastView
Could it not be a switch in the settings?
Just saying
dj
Perfect. As far as I’m concerned settings accessed in terminal are features. Thank you.
I used this previously, and it worked perfectly. When I tried it again today, nothing changed. Is there another way to achieve the same effect?
bchend
9
Which command have you tried, @mollybee ?
