Is it possible to enable deep linking with Good Links? For example reading an article and selecting a piece of text and then hooking that to a note in Craft? The context menu to copy link to selection is not currently active and I wondered if it was a limit of Good Links or just that it’s not implemented in Hook?
that’s a question for the developer, but to my knowledge they don’t have an API for that. (We worked with the developer, Ngoc Luu, to get the current API which is for resource level linking).
If GoodLinks had an “export to PDF” function , which it doesn’t, a work-around would be to convert the entry to PDF.
Thanks Luc, I’ll look into seeing if it can be converted to PDF. I wonder if once they have highlighting released it will be possible in their API.
some extra coding would be required.
