Hello!
It’s been months since macOS 14 Sonoma was released, So I just decided to updated to macOS 14 Sonoma (developer Beta5). Everything about Hookmark seem working fine after the updating, BUT (creating) deep link to Skim doesn’t work anymore.
I did a little testing. Only creating hookmark is affected (can’t do deeplink nor link to pdf document), while I still can open the deeplinks created before and jump to the right position. In other word, whether I select the text or directly invoke Hookmark in Skim, it will always prompt “No linkable item found in Skim”.
Is there anyway I could perhaps modify the scripts and fix the problem ASAP? It’s the feature I use heavily every day, and wish I could fix it without going back to the previous macOS version.
