For Skim, in order to get a deep link, the text needs be selected. When it is not working, could you please check if the link is deep link, it should have the similar format as the link below:
hook://file/TNio5IX0s?p=YmNoZW5kL0Rvd25sb2Fkcw==&n=test1%2Epdf#p=4&x=0&y=0&s=2737&e=3012
Here is an example of a non-deep link:
I wouldn’t know from your example. I do I attend to only the differences? What do they mean?
This link now points to the same text, as do all my links. Nothing is unique unless is simply opens the file: [Zenith](hook://file/TNGvxWDiD?p=RG9jdW1lbnRzL1BERnM=&n=Manyoshu%20The%20Complete%20Nippon%20Gakujutsu%20Shinkokai%20Translation%20%20%20%201965%2Epdf#p=36&x=0&y=0&s=975&e=980)
I find every time I make a link it takes the form of whatever is newest and so do older links which once went to unique texts when they are used either as hookmark files or bookmarks in the app become the same. In short, I have lots of links all linked to the same thing which once linked to different things.
Some of them solved this problem by reinstalling SKIM. Some of them solved the problem by giving Hookmark Full Disk Access. Could you please give them a try?
May I ask what’s your Hookmark version, script version(you can find it in Hookmark about window) and SKIM version? I assume you didn’t make any change to the script for SKIM in Hookmark preferences window, is this right?
For reasons I do not understand, Hookmark lost full disk access. I am sure I did not do this. I granted it again in Preferences. I suspect Ventura as it has been flaky with text input as of late. The cursor is not reliable, so possibly I did click it off unintentionally.
Certainly, disk access is why this problem happens, regardless.
I find a restart uncertain as to whether it helps. Afterwards, it jumps to the page, but not the location. Is this the expected behavior? Perhaps I do not understand what it should do.
The .pdf to which I am linking was made from an .rtf.
If you select text using Tools ->Text Tool, then it will jumps to the page and select the text;
If you select text using Tools ->Select Tool, then it will jumps to the location, but does not select the text.
