Is there a way to customize the markdown link? The typical syntax is:
and I’d like to generate a dokuwiki link:
[[URL|title]]
While it’s not hard to do by hand, it’s 5 seconds I’d like to save.
David
[[URL|title]]
David
I’m curious where you use this syntax - other than Wikipedia. But I would think a Keyboard Maestro macro or TextExpander substitution could help here, perhaps giving you a choice of output formats. Just a thought.
I use dokuwiki as a personal KB and like the two way linking, but also like seeing the links in my notes. Thanks for the idea!
Update: I obtained keyboard maestro and created a script to convert a markdown link to dokuwiki link using the regexp search tool. It didn’t take too long. I really like KM. Thanks for the idea @MartinPacker!
This is of course your first step into sinking sand…
Seriously, glad you like KM. With something called a Conflict Palette (and a second macro) you could easily make a menu for the 2 kinds of link.
Oh, I definitely see the sand. I am saving KM for what is worth the bother.
