Cursor not visible while renaming
Hi all, I am facing an issue while renaming a new hook entry.
For me, the cursor is practically not visible. If you check the screenshot, the cursor was behind the “_05” on the right of the five. I tried with dark mode and bright mode, no difference. Is there any way to address this?
Thank you very much. BR AWD
Thank you for reporting this issue and sorry about this, @AWD .
Thank you. I’ve been having a hard time renaming too. I have many weirdly named bookmarks and I’m trying to rename as I use them. However, not being able to see the cursor makes the task time consuming.
Thank you again for looking into this. I can’t wait for the update.
Glad to hear that I’m not the only one facing that issue. I cannot believe that nobody else has an issue with this.
It is just that it is a blue cursor on blue background.
Hope this gets addressed soon.
