Hi,
I’m new to both Hookmark and Eaglefiler and am exploring the possibilities.
I’m wondering wether or not it is possible to create a Hookmark link to a smart folder or a tag in Eaglefiler.
In Eaglefiler I can use the context menu option ‘Copy record link’ to create x-eaglefiler: links. But Hookmark is not able to do this, it gives the message ‘No linkable item found in Eaglefiler’.
Record links for tags look like this:
x-eaglefiler://open?library=~/Documents/Eaglefiler-library.eflibrary&tag=unread
Record links for Smart folders look like this:
x-eaglefiler://open?groupGUID=UserSmartGroupFolder.2368303B-F147-432E-A332-30949514752A&library=~/Documents/Eaglefiler-library.eflibrary
Is it possible to add this?
Regards,
René
Ps: I was writing this topic for the “Discussion & Help” category, but found the information on ‘No linkable Item’ so I can work with that for now.
