I don’t understand why only some apps are compatible with Hook’s built in “Copy Link and Selection” but I decided to build the functionality myself for web browsers.
tell application "System Events" to set the clipboard to ""
keystroke "c" using command down
delay 0.2
set theQuote to the clipboard as Unicode text
tell application "System Events" to set FrontAppName to name of first process where frontmost is true
if FrontAppName is "Microsoft Edge" then
tell application "Microsoft Edge"
set theName to title of active tab of front window
set theURL to URL of active tab of front window
else if FrontAppName is "Safari" then
tell application "Safari"
set theURL to URL of front document
set theName to name of front document
if theQuote is "" then
set the clipboard to "[" & theName & "](" & theURL & ")"
set the clipboard to ">" & theQuote & "\n[" & theName & "](" & theURL & ")"
display notification with title FrontAppName subtitle "Copied to clipboard"
Tweaked from this article to match Hook’s “Copy Link and Selection” style which also means that you can call up hook and paste the hook to a document. Hopefully, the Hook devs will add this functionality soon since this script is brittle (only works for the apps in the script). Also keep up the good work Hook devs!
