Hey,
I’m using Hookmark 6.0.1 (5788)(Scripts version 312) in Pro mode on a Mac Studio (Mac13,1 - 2022 - Apple M1 Max - 64 GB RAM) running macOS Ventura Version 13.6.3.
I’ve just discovered that the copied Hookmark-links don’t appear in LaunchBar’s Clipboard-History.
This happens both when copying the link in two steps (first showing Hookmark’s Context Window and then pressing CMD C) or directly (via the keyboard shortcut for “Hook to Copied Link”).
However the copied link is there and can be pasted via CMD V.
Do I miss something?
Thanks!
Regards,
Vlad
