Confused by different kinds of links
Started Using Hookmark again.
Confused about the difference between links, universal links, markdown links and the use cases/benefits/drawbacks of each.
@Redhawk Here is what my good friend Claude AI says of the links in Hookmark: Based on the official Hookmark documentation, here’s a clear summary of the differences between the link types:
Copy Link (⌘C)
Format: Creates a formatted hyperlink with both title and URL
  • Output: In rich text apps you get a clickable hyperlink; in plain text apps you get just the URL
  • URL schemes: Uses native app schemes (like omnifocus://, hook://email/, hook://file/) or https:// for web pages
  • Use case: General purpose linking across apps on your Mac
  • Limitation: Custom URLs (like omnifocus://) won’t work in web apps like Notion or Google Docs - they appear as plain text
Copy Markdown Link (⌘⇧M)
Format: Creates a markdown-formatted link: [Title](URL)
  • Output: Always gives you both title and URL in markdown format
  • URL schemes: Same as Copy Link (native app schemes or https://)
  • Use case: When pasting into plain text or markdown apps (like TaskPaper, BBEdit, Obsidian)
  • Benefit: Ensures you always get both title and URL, even in plain text fields
  • Limitation: Same as Copy Link - custom URLs won’t work in web apps
Copy as Universal Link (⌥⌘C)
Format: Creates a formatted hyperlink using https://hookmark.net/hm/ URLs
  • Output: Converts custom app URLs into web-accessible links
  • URL schemes: https://hookmark.net/hm/... (which Hookmark translates back to native schemes)
  • Use case:
    • Sharing links to emails with colleagues
    • Pasting links in web apps (Notion, Google Docs, Gmail) where custom URLs don’t work
  • Requirement: Only works in Safari (not Chrome/Firefox)
  • Limitation: Cannot be used for web pages or in web browsers
Copy as Universal Markdown Link (⌥⌘M)
Format: Markdown link with universal URL: [Title](https://hookmark.net/hm/...)
  • Output: Combines markdown formatting with universal link URLs
  • Use case: Same as Universal Link but in markdown format
  • Same limitations as Universal Link
Key Decision Guide:
  • Working only on your Mac → Use Copy Link or Copy Markdown Link
  • Pasting into web apps (Notion, Google Docs) → Use Universal Link
  • Sharing with colleagues → Use Universal Link (especially for emails)
  • Working in markdown apps → Use Copy Markdown Link
  • Need it to work in Chrome/Firefox → Stick with Copy Link (Universal won’t work)
Thank you @Pugless. Your friend provided an excellent rundown, just what I was looking for.
PS: You query just prompted me as I have had the exact same confusion. Your query motivated me to educate myself as well. Hookmark is a fantastic tool and I look forward to mastering it on iOS, but it appears even more arcane there than on the Mac. I need a 001 video.. :slight_smile:
A related notion is that each link returned by Hookmark has a URL scheme. Often apps define their own URL schemes, like x-devonthink-item:// or OmniFocus:// . Web links of course are the most common, and have the https:// URL scheme.
Sometimes however Hookmark returns links with its own hook:// URL schemes. Hookmark actually defines a number of hook:// URL sub-schemes. They are:
  • hook://addressbook: For Apple’s Contacts app.
  • hook://email/: for linking to emails in an email-client agnostic way (based on RFC email ID).
  • hook://file/: for linking to files in Finder.
  • hook://ical/ for Apple Calendar app links.
  • hook://macJournal/.
  • hook://notes/ for Using Hookmark with Apple Notes.
  • hook://outlook/, hook://outlook/task/, and hook://outlook/note/. However, note that Outlook’s IDs are not proper URLs.
  • hook://search/: triggers a Spotlight search.
  • hook://slack/ for the Slack app.
  • hook://spotify/for Spotify, obviously
  • hook://tbx/ for accessing Tinderbox items.
See Principles That Determine the URL Scheme Returned by Copy Link for a Given App – Hookmark.
Thank you @LucB A related question. If I link multiple urls to an obsidian note via the hook to copied link command, is there a way to paste them all into the obsidian note from the dialogue window?
On the source item that has multiple hooks, you can
  1. invoke Hookmark
  2. Choose Copy All Hooked Links (⌃C)
  3. paste the into the Obsidian note
Awesome. Just what I was looking for. Sorry I missed in documentation.
