I got Hookmark and Craft both from my Setapp subscription, but I can’t get items of Craft by using Hook. I could not find the craft app in the list of apps for creating new notes either, which appeared normally when I used Craft gotten from App Store.
Thanks for pointing that out. We’ll add a Setapp specific integration script on Tuesday. (Pro users can adapt the bundle before then using the Script Editor).
We have released an update on script server. Just use the Gear menu’s Check for App Updates and Update Scripts … or do same in Preferences window > Updates tab to get them.
But still facing the problem that no hooks are catched from Craft.
As soon as I deinstall the Craft version from App Store, the “Hook to new…Craft” disappears.
Hooks from Craft do not appear at all.
Script version (SetApp bundled): Version 2.4 (719)
BTW: deinstalled & reinstalled hookmark and Craft (SetApp bundle) 5-6 times with no countable result.
What’s your script version? If it is not 243, Could you please use the Gear menu’s Check for App Updates and Update Scripts … or do same in Preferences window > Updates tab to get them?
Could you be more specific? Or a screenshot please.
