Automation: Hook + OmniFocus + MailMate
I use a script (a “Command” in MailMate terms) to create a new OmniFocus task from an email. Well, technically, it opens the Quick Entry bar with some pre-filled fields. Is it possible to somehow get Hook to link the email and the Task at the same time?
Alternately, is it possible to set up a script in Hook that will do all the things my MM Command does (sets some tags, imports a bit more than just the name of the email and a link into OmniFocus)?
I find myself really struggling with OmniFocus these days and I think Hook could substantially ease my pain if I could quickly and easily get Hook to act as a connector between MailMate and OmniFocus (I don’t technically NEED Hook to be a connector between OF and MM, but hey, I’ll take it).
Any ideas?
Does the Hook to New> OmniFocus from Mailmate not do the trick? (I tried it and it still works for me.) that also adds a linkback into the OF task. Or is not good enough?
If Hook to New isn’t a good option, this should still be possible to automate. IIRC, the MailMate command just populates the Quick Entry window, so it’s not receiving a task ID back to use, but that could potentially be circumvented with a new MailMate command…
Oh it works, I’m looking to get a script going that does all of it at once instead of requiring a little concerto played out via keyboard with multiple invocations.
@ttscoff I think you are probably right that a new custom MailMate command is needed. I almost NEVER change the repopulated Quick Entry window and I would happily sacrifice the ability to modify the task name at creation if it auto-linked via Hook.
hey @apoc527 - I wonder if you were able to get an automation or setup sorted for working efficiently with MailMate and OmniFocus.
I was wondering the same thing. I am looking for a way to add my waiting mails to OmniFocus, such as
  1. Tagging a reply with “Waiting” tag
  2. Add a rule in the Sent folder on new mails with the “Waiting” tag to
    • add a new OF task with the Waiting tag in OF, the title “Wait for reply by `Recipient` on `subject`” and the MailMate link to the mail in the notes field
    • delete the “Waiting” tag on the mail itself to avoid clutter
Currently, I have
  1. set up a rule on tagged mails with “Waiting” to
    • forward the mail via OmniGroup’s Mail Drop
    • remove the waiting tag
  2. set up another rule on mails with the Mail Drop address as recipient’s address to
    • delete the mail to avoid clutter
but that still needs some adjustment in OF.
