"Ask Siri" keeps being triggered from context window
Hi! Using the shortcut to open the context window and create notes or hook links is my main way of interfacing with the app. Since MacOS updated and added compulsory ask Siri to context menus (sigh) I can’t use the context window reliably. Invoking it can trigger Siri and cause it to close instantly, or the window can remain only to disappear when I try to create a note or perform some other action. I’d like “Ask Siri” to be purged from Hookmark if possible, or for there to be an option to remove it at least. I am unable to find any keyboard shortcuts Mac OS has assigned to it so don’t think it’s a keyboard shortcut crowding issue. Hope this can be fixed.
I found it! They’ve added a Siri keyboard shortcut under Screenshots, “Ask Siri about the active Window” which is mapped to Command+Shift+Space. I killed that and the issue is gone. Hope this helps someone else – very strange place to expect me to look :smiley:
Excellent work, @Jan_Salomonsson .
Thank you for reporting this issue and sharing your solution with the Hookmark community!
