Anyone want to use use Hook with Versions - Mac Subversion Client (SVN)? If so, please let them know you’d like the feature: Contacting Developers of Other Apps and Information for Developers – Hook.
(We don’t use SVN for our code; but for some internal documentation).
We would do our part to enable you to link stuff with it. As it stands, I open versioned items and invoke Hook from there. the API support would save a step. Not a game changer, but every bit helps.
They’ve had a change of ownership, and a new version. I’m waiting for Hook integration before upgrading, as that is the only feature missing for me.
On Twitter they are Versions (@versionsapp) / Twitter.
I also use BBEdit for versioning. But sometimes BBEdit SVN commits fail where they don’t in Versions.
