Hi,
we are using Airmail for Business, which should have the same functionality as Airmail. Unfortunately, I cannot get linking to work (No linkable item found). Is there any way to make this work?
Thanks!
Hi,
Thanks!
Welcome to Hookmark forum, @anhi .
Could you please update Hookmark script and see if it fixes the problem?(Hookmark preferences window->Updates->Check now).
Script Version 329.
That worked, thank you!
