Hookmark 6.1 (5967) I’ve spotted a few instances in the Bookmarks window where there seem to be consecutive identical rows (same file reference, same set of linked items in the context window).
And they are duplicates - adding a tag to one of the duplicate items adds the tag to all of them.
Could you please tell me which section (window, panel) the duplicate items are displayed? Thank you. Did you use the Sync feature of Hookmark?
In the bookmarks pane, non tabular view. Not used Sync feature.
Thank you for reporting this issue and sorry about this, @atdnorth .
Could you please do “copy link” for the duplicates and post them here?
[Famiy Project Ideas.ooutline](hook://file/zJVunwRQ0?p=UHJvamVjdHMvRmFtaWx5&n=Famiy%20Project%20Ideas%2Eooutline)
And another example
which looks like:
[viewpoints_metamodel_description.graffle](hook://file/rWr3KKPaU?p=TWV0YW1vZGVsIFZpZXdwb2ludCBEZWZpbml0aW9uL0ZpZ3VyZXM=&n=viewpoints%5Fmetamodel%5Fdescription%2Egraffle)
If I delete one of the duplicated entries, all the duplicated entries are deleted.
Thank you and sorry about this, @curl .
We will try to reproduce the problem.
What’s your Hookmark version?
I currently am using:
Version 6.11 (6343; Integration v. 384)
Thank you, @atdnorth .
I am trying to reproduce the problem, but no luck yet.
Is this in All bookmarks view? How many bookmarks do you have?
Do all your bookmarks have duplicate items? If not, could you please post the screenshot of the bookmarks that don’t duplicates?
It shows up in both All bookmark and Tag views. I have over 600 bookmarks.
Only a subset of bookmarks duplicate. I can’t give a specific scenario in which they occur. However, I will state that I use tags, rename tags, and use “Copy all hooked links” fairly frequently.
And “interestingly”, if I delete one of the duplicated entries, all the duplicated entries for that specific object also are deleted (so they must be related in some fashion)
Now using Version 6.11.1 (6345; Integration v. 384) but the bug has been around for months.
c 4100 bookmarks.
It has occurred many times - see attached.
Thank you for the info, @curl .
Are these bookmarks newly created or they have been created for a while?
Probably some while ago.
Out of interest I’ve looked at the Recent list of bookmarks to see if this stopped some while ago - that is also showing 5 sets of duplicates, so it looks as though it is continuing to sometimes create duplicates.
Thank you, @curl .
Could you please post a screenshot of those duplicates in recent views, including the timestamp?
The duplicates that are occurring are recent and continue to occur.
Regarding those duplicates, do you happen to remember what you did with them? I am trying to reproduce the problem on my mac. But so far, no luck.
