It has been my experience that this works as you describe: Hook allows linking to and from specific documents within a Scrivener project.
that’s right.
If the setting is English. UI scripts need localized versions. We intend to internationalize the Scrivener integration.
thanks for the quick reply(s). I’ve blocked time out for this item, this week. I’ll keep you in the loop.
Luc, any examples or videos on EXACTLY how you’ve used Scrivener with Hook? I was thrilled to find that there is an integration. I am using it, but just out of curiosity, wanted to know if I’m missing something.
Hi Luc,
OK, some hand holding is needed on my part.
∞1 I’ve read through the above.
∞2 I see the code in Hook app > preference > Scrivener > Get Address (thanks Rob Trew)
∞3 But when I’m in Scrivener with a scrivener document selected and invoke the hook app the resulting window displays the “No Linkable items in Scrivener” window.
What am I missing and how do I use hook to link a scrivener doc to other items?
Thank you! we’ll internationalize Scrivener.
We had hoped to be further along internationalization by now (the entire app). It is a priority for 2.3 / 2.4.
