PDF Expert integration scripts
it seems that you have to try the different possibilities and look what works for you…
For me, deep linking is working (and also opening these deep-links).
I am using the scipts posted by lawyerboy (post) but i had to edit them slightly, to get deep linking working again.
I think i only changed the getPageDetails() function, but i will just post my current config
openItem
use framework "Foundation"
property NSURLComponents : a reference to current application's NSURLComponents
property NSURLQueryItem : a reference to current application's NSURLQueryItem
property NSMutableDictionary : a reference to current application's NSMutableDictionary
property NSFileManager : a reference to current application's NSFileManager's defaultManager
on getPDFExpertName()
	tell application "System Events" to return name of first window of process "PDF Expert"
end getPDFExpertName
on replaceText(this_text, search_string, replacement_string)
	set str to current application's NSString's stringWithString:this_text
	return (str's stringByReplacingOccurrencesOfString:search_string withString:replacement_string) as string
end replaceText
on cleanURL(fullURL)
	--Clean up historic bad encodings
	if fullURL contains "%2520" then
		set fullURL to replaceText(fullURL, "%25", "%")
		set fullURL to replaceText(fullURL, "%23", "#")
		set fullURL to replaceText(fullURL, "&#40", "(")
		set fullURL to replaceText(fullURL, "&#41", ")")
	set fullURL to replaceText(fullURL, ".pdf&", ".pdf?")
	set urlObj to NSURLComponents's componentsWithString:fullURL
	--Handle Hook file URLs by stripping the '/file:/' component from the start of the path
	set AppleScript's text item delimiters to "file:/"
	get (urlObj's |path| as string)'s text items
		if (urlObj's |path| as string)'s second text item is not "" then set urlObj's |path| to (urlObj's |path| as string)'s second text item
	--Handle old-style paths (which appear with a leading / ...)
	if ((urlObj's |path|) as string) contains ":Users:" then set urlObj's |path| to (POSIX path of (text 2 thru end of (urlObj's |path| as string)))
	--Optional: search for files where there is no match
	if not (NSFileManager's fileExistsAtPath:(urlObj's |path|)) then
		set newObj to findItemURL(urlObj)
		if newObj is not missing value then set urlObj's |path| to newObj's |path|
	return urlObj
end cleanURL
	set {urlObj's |scheme|, urlObj's |host|} to {"file", ""}
	set filename to urlObj's |URL|'s lastPathComponent
	set searchResults to do shell script "mdfind -name " & quoted form of (filename as string)
	set searchResultURLs to {}
	repeat with searchResult in paragraphs of searchResults
		set end of searchResultURLs to (NSURL's fileURLWithPath:searchResult isDirectory:false relativeToURL:(urlObj's |URL|))
	set ourPathComponents to urlObj's |URL|'s pathComponents
	set leadingCandidate to {_URL:missing value, penalty:999999}
	repeat with searchResultURL in searchResultURLs
		set diff to ((searchResultURL's pathComponents)'s differenceFromArray:ourPathComponents)
		set penalty to (count of (diff's insertions)) + (count of (diff's removals))
		if penalty < leadingCandidate's penalty then set leadingCandidate to {_URL:searchResultURL, penalty:penalty}
	return contents of leadingCandidate's _URL
end findItemURL
on getKvs(fromURLComponents)
	if fromURLComponents's query() is missing value then
		set fromURLComponents's query to fromURLComponents's fragment()
		set fromURLComponents's fragment to ""
	set dict to NSMutableDictionary's new()
		repeat with queryItem in fromURLComponents's queryItems
			(dict's setValue:(queryItem's value as string) forKey:(queryItem's |name|))
	return dict as record
end getKvs
on moveViewToPage(pageNo)
	set enabledViewElements to missing value
	tell application "PDF Expert" to activate
		tell application process "PDF Expert"
			if role description of value of attribute "AXFocusedUIElement" is "text field" then --Search bar taking focus?
				key code 53
			tell menu bar 1
				set goToPage to menu item "Go to Page..." of menu "Go"
				if goToPage's enabled is not true then
					--Side bar taking focus?
					set enabledViewElements to every UI element of menu "View" whose (value of attribute "AXMenuItemMarkChar" of it) is equal to "✓"
					keystroke "5" using {command down, option down} --faster than click UI element "No Left Panel" of menu "View"
				click goToPage
				delay 0.05
				keystroke pageNo
				keystroke return
				--Restore side bar if necessary
				if enabledViewElements is not missing value then
					repeat with element in enabledViewElements
						if element's name is in {"Bookmarks", "Outline", "Annotation Summary", "Thumbnails Panel"} then
							click element
end moveViewToPage
on openItem(fullURL)
	set urlObj to cleanURL(fullURL)
	--Test if file exists
		display dialog "Unable to find file for URL " & fullURL & " looking at path " & urlObj's |path| with title "Hook PDF Expert Integration" buttons {"OK"} default button 1 cancel button 1 giving up after 2
		return urlObj's |path|
	--Convert URL to file URL
	set furl to urlObj's |URL| as «class furl»
	tell application "PDF Expert" to open location furl
	-- Get page number
	set pageRefs to getKvs(urlObj) & {p:missing value, page:missing value} --Neuberg p. 241
	if pageRefs's p is missing value then set pageRefs's p to pageRefs's page
	set p to pageRefs's p
	if p is missing value then return
	--display dialog "Go to page " & p giving up after 1
	-- Get file name
	tell application "Finder" to set pdfName to displayed name of (info for furl)
	set AppleScript's text item delimiters to ".pdf"
	set pdfName to pdfName's first text item
	-- Move to page
	set counter to 30
	repeat while counter is greater than 0
		if getPDFExpertName() contains pdfName then
			moveViewToPage(p)
			return
			delay 0.1
		set counter to counter - 1
end openItem
openItem("$0")
getName
set oldDelimiters to applescript's text item delimiters
to getPageNo()
			tell process "PDF Expert"
				set pageText to value of static text 1 of splitter group 1 of window 1
		set AppleScript's text item delimiters to {" of "}
		get pageText's first text item
end getPageNo
	set fileName to name of first window of process "PDF Expert"
set fullName to fileName & " p. " & getPageNo()
set applescript's text item delimiters to oldDelimiters
get fullName
getAddress
use AppleScript version “2.4” – Yosemite (10.10) or later
use framework “Foundation”
property NSURLComponents : a reference to current application’s NSURLComponents
property NSURLQueryItem : a reference to current application’s NSURLQueryItem
property NSMutableDictionary : a reference to current application’s NSMutableDictionary
property NSFileManager : a reference to current application’s NSFileManager’s defaultManager
property NSURL : a reference to current application’s NSURL
–Get Address
on getPDFExpertFileURL()
local fileURL
set fileURL to missing value
tell application “System Events”
activate application “PDF Expert”
tell process “PDF Expert” to set showInFinder to menu item “Show in Finder” of menu 1 of menu bar item “File” of menu bar 1
set isEnabled to showInFinder’s enabled
if isEnabled then
tell application “System Events” to tell process “PDF Expert” to click showInFinder
delay 0.1
tell application “Finder”
set openWindows to id of every window
set fileURL to URL of (selection as alias)
close (get (every window whose id of it is not in openWindows))
tell application “System Events” to activate application “PDF Expert”
return fileURL
end getPDFExpertFileURL
tell application “System Events” to return name of first window of process “PDF Expert”
on getPageDetails()
set {pageNo, pageLabel} to {missing value, missing value}
try --Get the details we need
set frontmost to true
click menu item “Go to Page…” of menu 1 of menu bar item “Go” of menu bar 1
click menu item “Copy” of menu 1 of menu bar item “Edit” of menu bar 1
tell application “System Events” to key code 53
set pageNo to the clipboard
set pageLabel to the clipboard
return {pageNo, pageLabel}
end getPageDetails
on getAddress()
set urlBuilder to NSURLComponents’s new’s initWithString:getPDFExpertFileURL()
set {urlBuilder’s |scheme|, urlBuilder’s |host|} to {“pdfexpert”, “”}
set title to getPDFExpertName()
set {pageNo, pageLabel} to getPageDetails()
if pageNo is not missing value then
	set title to title & " p. " & pageLabel
	set urlBuilder's queryItems to {NSURLQueryItem's queryItemWithName:"p" value:pageNo}
	--set urlBuilder's fragment to "page=" & pageNo --necessary for file:/ scheme
return "[" & title & "](" & (urlBuilder's |string| as string) & ")"
end getAddress
getAddress()
Thanks much count_zero!.. Can you also let me know exactly what you’re putting in the “scheme” window?
:laughing: oh, i never even saw the “scheme” input field on the “Open Item” tab. I didn’t change it.
pdfexpert
Thanks again… at this point, for me, PDF Expert just not even seeing it (no linkable item found in PDF Expert)… seems like I will need to move to PDF Pen Pro, as it seems to just work consistently.
I modified it a little, and this works for me.
Open Item
end replaceText
	return urlObj
end cleanURL
end findItemURL
end getKvs
				key code 53
			tell menu bar 1
				click goToPage
				delay 0.05
				keystroke pageNo
				keystroke return
							click element
end moveViewToPage
	-- Get page number
	-- Get file name
	-- Move to page
	set counter to 30
			moveViewToPage(p)
			return
			delay 0.1
end openItem
openItem("$0")
Get address
--Get Address
	local fileURL
		activate application "PDF Expert"
		tell process "PDF Expert" to set showInFinder to menu item "Show in Finder" of menu 1 of menu bar item "File" of menu bar 1
		set isEnabled to showInFinder's enabled
	if isEnabled then
		tell application "System Events" to tell process "PDF Expert" to click showInFinder
		delay 0.1
	tell application "System Events" to activate application "PDF Expert"
	return fileURL
on getPageDetails()
			click menu item "Go to Page..." of menu 1 of menu bar item "Go" of menu bar 1
			click menu item "Copy" of menu 1 of menu bar item "Edit" of menu bar 1
			tell application "System Events" to key code 53
end getPageDetails
on getAddress()
	set urlBuilder to NSURLComponents's new's initWithString:getPDFExpertFileURL()
	set {urlBuilder's |scheme|, urlBuilder's |host|} to {"file", ""}
	return "[" & title & "](" & (urlBuilder's |string| as string) & "#p=" & pageNo & ")"
end getAddress
getAddress()
That is awesome!! Works great now- thanks!
I have changed the script (Get address) a little bit, and this time it can auto close the opened finder window.
But it seems that if the file name contains other languages like Chinese, then it will fail to go to the specific page. I don’t know how to improve it. Hope someone can improve it.
Get address
--Get Address
	local fileURL
	if isEnabled then
		delay 0.1
			close(get (every window whose id of it is not in openWindows))
			close Finder window 1
	return fileURL
on getPageDetails()
end getPageDetails
on getAddress()
end getAddress
getAddress()
It works!
You’re a lifesaver and you’ve also solved the problem Finder window issue.
Thank you so much.
Thanks a lot for the scrip! Unfortunately I cannot get it running. Are newer versions not working? The post is from 2019. Any experiences or hints?
Similarly hoping for some updates here - I also can’t seem to get this to work.
