also completely new to this, just interested whether this script can be tweaked to link to specific pages within pdf files within pdf expert as well?
Welcome to the Hook Productivity Forum , @amisean . No that isn’t something we’ve looked into yet. If they add an API for it ( x-callback-url, ,AppleScript, CLI, whatever,) we’d gladly look into it.
awesome! thanks for the reply! going to drop them a message to get going with this👌🏾
I have been able to tweak the scripts to do this as below:
Open Item
set theURL to "$0"
set oldDelimiters to applescript's text item delimiters
set applescript's text item delimiters to "pdfexpert://file:/"
set baseURL to theURL's second text item
set applescript's text item delimiters to "&"
set urlComponents to baseURL's text items
set pageCode to urlComponents's second text item
set applescript's text item delimiters to "="
set pageNo to pageCode's second text item
set openScript to "open -a 'PDF Expert.app' 'file:///" & urlComponents's first item & "'"
do shell script openScript
delay 0.3
keystroke "g" using {command down, option down}
delay 0.1
keystroke pageNo
keystroke return
set applescript's text item delimiters to oldDelimiters
Get Name
to getPageNo()
tell process "PDF Expert"
set pageText to value of static text 1 of splitter group 1 of window 1
set AppleScript's text item delimiters to {" of "}
get pageText's first text item
end getPageNo
set fileName to name of first window of process "PDF Expert"
set fullName to fileName & " p. " & getPageNo()
get fullName
Get Address
to getPageNo()
end getPageNo
set encodedPageURLFragment to "&p="&getPageNo()
if enabled of menu item "Show in Finder" of menu 1 of menu bar item "File" of menu bar 1 then
click menu item "Show in Finder" of menu 1 of menu bar item "File" of menu bar 1
delay 0.1
tell application "Finder"
set theItems to selection
set ext to name extension of item 1 of theItems
if ext = "hook" or ext = "HOOK" then
set filepath to item 1 of theItems as alias
return read POSIX path of filepath
set theURL to URL of item 1 of theItems
close front window
activate application "PDF Expert"
set finalURL to "pdfexpert:///"&theURL&encodedPageURLFragment
get finalURL
Notes:
- In PDF Expert’s preferences you will need to set Page Number indicator to Show always.
- The URL scheme is pdfexpert://. NB that Readdle has some url schemes albeit they don’t seem to work on the Mac; I chose pdfexpert to avoid conflicting with them.
- I strongly suspect the code could be improved, in particular in the Open Item script where I am sure I have not found the most elegant way to handle the URL!
Hi Lawyerboy!
I’ve tried your apple script. Unfortunately they don’t seem to work for me. The saving link seems good, but I’m difficulty opening items. Any pointers?
I’m on Monterey btw
Worth checking you’ve set the url scheme?
Otherwise try putting a ‘display dialog openScript’ before the ‘do shell script’ line in Open Item, and seeing if you can execute what pops up in the terminal?
Hi, thanks for the timely reply
I’ve set the url scheme to pdfexpert:// in the text box. I’ve tried to put a display diaglog openScript before the line you mentioned, but nothing showed up
I had to use
set applescript's text item delimiters to "pdfexpert:///file:///"
to make it work. Seems there’re more forward slashes for some reason
I knew I wasn’t happy with the URL-handling code! Also wasn’t very happy with the ‘do shell script’ line with potentially untrusted input. I had a look at the PDFPen Pro scripts and was able to rewrite the script using that code, which I think is a bit neater:
Get Address
use framework "Foundation"
property NSMutableCharacterSet : a reference to current application's NSMutableCharacterSet
on urlEncode(input)
tell current application's NSString to set rawUrl to stringWithString_(input)
set charset to NSMutableCharacterSet's URLQueryAllowedCharacterSet's mutableCopy
charset's removeCharactersInString:"?"
set theEncodedURL to rawUrl's stringByAddingPercentEncodingWithAllowedCharacters:charset
return theEncodedURL as Unicode text
end urlEncode
on getPageNo()
return pageText's first text item
on error
return ""
end getPageNo
on getPDFExpertName()
return name of first window of process "PDF Expert"
end getPDFExpertName
on getPDFExpertFilePath()
tell process "PDF Expert" to set showInFinder to menu item "Show in Finder" of menu 1 of menu bar item "File" of menu bar 1
set isEnabled to showInFinder's enabled
if isEnabled then
tell application "System Events" to tell process "PDF Expert" to click showInFinder
delay 0.1
set sel to selection
set filePath to (item 1 of sel) as string
close front window
tell application "System Events" to activate application "PDF Expert"
return filePath
on error
return ""
end getPDFExpertFilePath
on getAddress()
set filePath to getPDFExpertFilePath()
set pageNo to getPageNo()
set title to getPDFExpertName()
if pageNo = "" then
get "[" & title & "](pdfexpert://" & urlEncode(POSIX path of filePath) & ")"
get "[" & title & " p. " & pageNo & "](pdfexpert://" & urlEncode(POSIX path of filePath) & "#p=" & pageNo & ")"
end getAddress
set theLink to getAddress()
Open Item
on urlDecode(input)
tell current application's NSString to set urlString to stringWithString_(input)
set theDecodedURL to urlString's stringByRemovingPercentEncoding -- 4 is NSUTF8StringEncoding
return theDecodedURL as Unicode text
end urlDecode
on moveViewToPage(pageNo)
tell application "PDF Expert" to activate
tell application process "PDF Expert"
set goToPage to menu item "Go to Page..." of menu "Go" of menu bar item "Go" of menu bar 1
if goToPage's enabled is false then
key code 53 --esc to remove focus from search box, bookmarks bar etc.
if goToPage's enabled then
click goToPage
delay 0.1
keystroke pageNo
keystroke return
end moveViewToPage
on openItem(fullURL)
set AppleScript's text item delimiters to "#"
set urlPath to text item 1 of fullURL
if (count of text items of fullURL) is greater than 1 then
set fragment to text item 2 of fullURL
set AppleScript's text item delimiters to "&"
set kvs to text items of fragment
repeat with kv in kvs
set AppleScript's text item delimiters to "="
set k to text item 1 of kv
set v to text item 2 of kv
if k = "p" then
set p to v as number
set fpath to urlDecode(urlPath)
set text item delimiters to "/"
set fn to text item -1 of fpath
set len to length of fpath
set fpath to text 12 through len of fpath
if application "PDF Expert" is not running then
tell application "PDF Expert" to open ""
delay 2
ignoring application responses
tell application "PDF Expert" to open fpath
end ignoring
if p is not missing value then
delay 0.8
moveViewToPage(p)
end openItem
openItem("$0")
lol your new script stopped working again. Any idea how I can help to debug? For some reason it runs correctly in script editor but not correctly in hook
Seems have to change the identifier to pdfexpert rather than pdfexpert://
this does the trick for me. thank you so much!
Ah, yes, although I think the new version is probably better than the old.
@LucB More generally I tried not specifying an identifier and returning a file:// link, but when I did that the link title was always the filename of the document even if the scripts returned a customised title (either as a separate Get Name script or by returning a markdown link from Get Address). Is that expected behaviour?
It would seem better to use the file:// scheme if possible because that would make the links cross-compatible to some degree with other PDF apps (e.g. the PDFPenPro deep links seem to encode a page number which PDF Expert can be made to open to). However at least for my purposes, I want the link title to have the page number so I can paste it into my notes!
There seems to be an issue on Hook’s side with specifying the name in this case. We will look into that.
I think you mean hook://file/ URLs? That’s what we use for the other PDF apps. We are looking into that.
Yes, this was what I meant!
Hello, Lawyerboy. I’ve tried your code but unfortunately it does not work for me. Is there any chance you might update or give me some advice? (I’m new around here
I am working on another version but need to iron out a couple of bugs on my own setup first!
These are the scripts I’m currently using.
Get Address
property NSURLComponents : a reference to current application's NSURLComponents
property NSURLQueryItem : a reference to current application's NSURLQueryItem
property NSMutableDictionary : a reference to current application's NSMutableDictionary
property NSFileManager : a reference to current application's NSFileManager's defaultManager
--Get Address
on getPDFExpertFileURL()
local fileURL
set fileURL to missing value
if isEnabled then
delay 0.1
set openWindows to id of every window
set fileURL to URL of (selection as alias)
close (get (every window whose id of it is not in openWindows))
return fileURL
end getPDFExpertFileURL
tell application "System Events" to return name of first window of process "PDF Expert"
on getPageDetails()
set {pageNo, pageLabel} to {missing value, missing value}
try --Get the details we need
set pageNoText to value of static text 1 of splitter group 1 of window 1
set pageLabelText to value of static text 2 of splitter group 1 of window 1
try --Set pageNo
set pageNo to pageNoText's first text item
try --Only try setting pageLabel if the value may make sense
if (pageLabelText starts with "Back to ") or (pageLabelText starts with "Go to") or (pageLabelText = "") or (pageLabelText is missing value) then error
set pageLabel to pageLabelText
on error
set pageLabel to pageNo
return {pageNo, pageLabel}
end getPageDetails
on getAddress()
set urlBuilder to NSURLComponents's new's initWithString:getPDFExpertFileURL()
set {urlBuilder's |scheme|, urlBuilder's |host|} to {"pdfexpert", ""}
set {pageNo, pageLabel} to getPageDetails()
if pageNo is not missing value then
set title to title & " p. " & pageLabel
set urlBuilder's queryItems to {NSURLQueryItem's queryItemWithName:"p" value:pageNo}
--set urlBuilder's fragment to "page=" & pageNo --necessary for file:/ scheme
return "[" & title & "](" & (urlBuilder's |string| as string) & ")"
end getAddress
getAddress()
Open Item
on replaceText(this_text, search_string, replacement_string)
set str to current application's NSString's stringWithString:this_text
return (str's stringByReplacingOccurrencesOfString:search_string withString:replacement_string) as string
end replaceText
on cleanURL(fullURL)
--Clean up historic bad encodings
if fullURL contains "%2520" then
set fullURL to replaceText(fullURL, "%25", "%")
set fullURL to replaceText(fullURL, "%23", "#")
set fullURL to replaceText(fullURL, "(", "(")
set fullURL to replaceText(fullURL, ")", ")")
set fullURL to replaceText(fullURL, ".pdf&", ".pdf?")
set urlObj to NSURLComponents's componentsWithString:fullURL
--Handle Hook file URLs by stripping the '/file:/' component from the start of the path
set AppleScript's text item delimiters to "file:/"
get (urlObj's |path| as string)'s text items
if (urlObj's |path| as string)'s second text item is not "" then set urlObj's |path| to (urlObj's |path| as string)'s second text item
--Handle old-style paths (which appear with a leading / ...)
if ((urlObj's |path|) as string) contains ":Users:" then set urlObj's |path| to (POSIX path of (text 2 thru end of (urlObj's |path| as string)))
--Optional: search for files where there is no match
if not (NSFileManager's fileExistsAtPath:(urlObj's |path|)) then
set newObj to findItemURL(urlObj)
if newObj is not missing value then set urlObj's |path| to newObj's |path|
return urlObj
end cleanURL
set {urlObj's |scheme|, urlObj's |host|} to {"file", ""}
set filename to urlObj's |URL|'s lastPathComponent
set searchResults to do shell script "mdfind -name " & quoted form of (filename as string)
set searchResultURLs to {}
repeat with searchResult in paragraphs of searchResults
set end of searchResultURLs to (NSURL's fileURLWithPath:searchResult isDirectory:false relativeToURL:(urlObj's |URL|))
set ourPathComponents to urlObj's |URL|'s pathComponents
set leadingCandidate to {_URL:missing value, penalty:999999}
repeat with searchResultURL in searchResultURLs
set diff to ((searchResultURL's pathComponents)'s differenceFromArray:ourPathComponents)
set penalty to (count of (diff's insertions)) + (count of (diff's removals))
if penalty < leadingCandidate's penalty then set leadingCandidate to {_URL:searchResultURL, penalty:penalty}
return contents of leadingCandidate's _URL
end findItemURL
on getKvs(fromURLComponents)
if fromURLComponents's query() is missing value then
set fromURLComponents's query to fromURLComponents's fragment()
set fromURLComponents's fragment to ""
set dict to NSMutableDictionary's new()
repeat with queryItem in fromURLComponents's queryItems
(dict's setValue:(queryItem's value as string) forKey:(queryItem's |name|))
return dict as record
end getKvs
set enabledViewElements to missing value
if role description of value of attribute "AXFocusedUIElement" is "text field" then --Search bar taking focus?
key code 53
tell menu bar 1
if goToPage's enabled is not true then
--Side bar taking focus?
set enabledViewElements to every UI element of menu "View" whose (value of attribute "AXMenuItemMarkChar" of it) is equal to "✓"
keystroke "5" using {command down, option down} --faster than click UI element "No Left Panel" of menu "View"
click goToPage
delay 0.05
keystroke pageNo
keystroke return
--Restore side bar if necessary
if enabledViewElements is not missing value then
repeat with element in enabledViewElements
if element's name is in {"Bookmarks", "Outline", "Annotation Summary", "Thumbnails Panel"} then
click element
end moveViewToPage
set urlObj to cleanURL(fullURL)
--Test if file exists
display dialog "Unable to find file for URL " & fullURL & " looking at path " & urlObj's |path| with title "Hook PDF Expert Integration" buttons {"OK"} default button 1 cancel button 1 giving up after 2
return urlObj's |path|
--Convert URL to file URL
set furl to urlObj's |URL| as «class furl»
tell application "PDF Expert" to open location furl
-- Get page number
set pageRefs to getKvs(urlObj) & {p:missing value, page:missing value} --Neuberg p. 241
if pageRefs's p is missing value then set pageRefs's p to pageRefs's page
set p to pageRefs's p
if p is missing value then return
--display dialog "Go to page " & p giving up after 1
-- Get file name
tell application "Finder" to set pdfName to displayed name of (info for furl)
set AppleScript's text item delimiters to ".pdf"
set pdfName to pdfName's first text item
-- Move to page
set counter to 30
repeat while counter is greater than 0
if getPDFExpertName() contains pdfName then
moveViewToPage(p)
return
delay 0.1
set counter to counter - 1
end openItem
openItem("$0")
Thank you for the script!
I can’t seem to get it to work, can I ask what URL scheme you are using now? Thanks!
Hi Steve, sorry to bother you, but is this script still working? I copied it into the hook but I always get “No item or link” feedback, I would like to know if you could help me. Thank you very much! (PS, What is the url scheme you entered? )
